one ninety hydraulic pump ?
where is the hydrualic pump located on the one
ninety, had the hay bine and both levers would not
move rams, only if I put tractor in neutral, reved
way up and then they would move but very slow, tried
another tractor haybine operated ok.
Thanks in advance for any input
Hyd pump is on LS front of eng. There is a screen on the suction tube that could get plugged and first and foremost is it full of oil.
Toward the rear on the left side of the engine, behind the frame, there are clamps on the suction tube that can leak air into the pump.
