TractorLinks.com
Show Parts for Model:
Re: WD front wheel wobble correction?
Farmallb
05-29-2014 10:27:22
Im talking about the bearing at the bottom of the steering post. AFTER you take out the spindles that hold the wheels, at the bottom end of the steering post is a bearing. Its in there, but its way loose.
bg/mo
05-29-2014 11:00:55
 Re: WD front wheel wobble correction? in reply to Farmallb, 05-29-2014 10:27:22
there should be shims under the bolt that hold the spindle assembly on the shaft to remove play,and then the setscrew on the front holds it to the key.
Farmallb
05-29-2014 13:00:55
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-29-2014 11:00:55
We didn't see any shims when we took it off. The spindle assembly fits tight enough. Its just that the bearing that goes around the inner shaft that the keyway 1/2 way fits into is bad.
