TractorLinks.com
Show Parts for Model:
Re: WD front wheel wobble correction?
48C-MAN
05-28-2014 10:36:07
Just curious, but what does that set screw do? I saw it there but didn't know what it does.
bg/mo
05-28-2014 10:48:14
 Re: WD front wheel wobble correction? in reply to 48C-MAN, 05-28-2014 10:36:07
locks the spindles on the shaft ,its on a keyway and thru the years gets loose on the key. I have tightened that bolt up on several tractors and it fixed the wobble
Farmallb
05-29-2014 06:47:06
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-28-2014 10:48:14
Take a GOOD look at the bottom bearing nest to that bolt there talking about above. On my sons WD, the bearing is there, but its loose.
bg/mo
05-29-2014 06:54:52
 Re: WD front wheel wobble correction? in reply to Farmallb, 05-29-2014 06:47:06
Do you mean where the bearing rides on the spindle??? usually have to flatten the spindle out cause it has grooves in it from the bearing. and then just shim it back to tight. what part is loose on yours?
Farmallb
05-29-2014 10:27:22
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-29-2014 06:54:52
Im talking about the bearing at the bottom of the steering post. AFTER you take out the spindles that hold the wheels, at the bottom end of the steering post is a bearing. Its in there, but its way loose.
bg/mo
05-29-2014 11:00:55
 Re: WD front wheel wobble correction? in reply to Farmallb, 05-29-2014 10:27:22
there should be shims under the bolt that hold the spindle assembly on the shaft to remove play,and then the setscrew on the front holds it to the key.
Farmallb
05-29-2014 13:00:55
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-29-2014 11:00:55
We didn't see any shims when we took it off. The spindle assembly fits tight enough. Its just that the bearing that goes around the inner shaft that the keyway 1/2 way fits into is bad.
