Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
WD front wheel wobble correction?
48C-MAN
05-28-2014 08:11:09
24.181.146.226
What are the most likely causes of front wheel wobble on a narrow front WD? The wheel bearings are proper. Thanks
[Reply]   [No Email]
Tom RS
05-30-2014 19:29:05
75.205.134.11
 Re: WD front wheel wobble correction? in reply to 48C-MAN, 05-28-2014 08:11:09
Had the same problem on our WC 1937. All of the problems mentioned needed attention AND the wheel bearings were worn beyond just needing take up.
Fixed the loose pin in the worm gear, replaced the really shot lower spindle bearing, replaced the wheel bearings and made sure the races fit tight on the spindles, shimmed the lower nut on the spindle to snug up the bearing and all was good. No more Death Wobble.
[Reply]  [No Email]
hd6gtom
05-28-2014 10:52:32
63.153.192.131
You may also find the 2 bearings on the steering gearbox input shaft bad. That was the problem with dads WD45.
[Reply]  [No Email]
bg/mo
05-28-2014 09:41:41
204.54.154.68
check the set screw on the front between the front wheels, and the bearings in the shaft up to the gearbox.
[Reply]  [No Email]
48C-MAN
05-28-2014 10:36:07
24.181.146.226
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-28-2014 09:41:41
Just curious, but what does that set screw do? I saw it there but didn't know what it does.
[Reply]  [No Email]
bg/mo
05-28-2014 10:48:14
204.54.154.68
 Re: WD front wheel wobble correction? in reply to 48C-MAN, 05-28-2014 10:36:07
locks the spindles on the shaft ,its on a keyway and thru the years gets loose on the key. I have tightened that bolt up on several tractors and it fixed the wobble
[Reply]  [No Email]
Farmallb
05-29-2014 06:47:06
72.171.24.186
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-28-2014 10:48:14
Take a GOOD look at the bottom bearing nest to that bolt there talking about above. On my sons WD, the bearing is there, but its loose.
[Reply]  [No Email]
bg/mo
05-29-2014 06:54:52
204.54.154.68
 Re: WD front wheel wobble correction? in reply to Farmallb, 05-29-2014 06:47:06
Do you mean where the bearing rides on the spindle??? usually have to flatten the spindle out cause it has grooves in it from the bearing. and then just shim it back to tight. what part is loose on yours?
[Reply]  [No Email]
Farmallb
05-29-2014 10:27:22
72.171.24.183
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-29-2014 06:54:52
Im talking about the bearing at the bottom of the steering post. AFTER you take out the spindles that hold the wheels, at the bottom end of the steering post is a bearing. Its in there, but its way loose.
[Reply]  [No Email]
bg/mo
05-29-2014 11:00:55
204.54.154.68
 Re: WD front wheel wobble correction? in reply to Farmallb, 05-29-2014 10:27:22
there should be shims under the bolt that hold the spindle assembly on the shaft to remove play,and then the setscrew on the front holds it to the key.
[Reply]  [No Email]
Farmallb
05-29-2014 13:00:55
72.171.24.185
 Re: WD front wheel wobble correction? in reply to bg/mo, 05-29-2014 11:00:55
We didn't see any shims when we took it off. The spindle assembly fits tight enough. Its just that the bearing that goes around the inner shaft that the keyway 1/2 way fits into is bad.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
