Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: WD continues to diesel after shut down
05-28-2014 07:26:40
Hot spot from carbon build up was uncles problem- but since you put in new cran and pistons the head should have been cleaned. Try to use fuel shutoff drill instead of ignition off and see if that helps. WD45 crank was stroked compared to wd- 4.5 instead of 4 inch. What rods are you using? the old WD rods? WD45? Need to double check but rod length was a tad shorter on the later WD45? means the older rod and newer piston rated for 8.5 to one is actually pushed up higher in cylinder and compression is 9.5/10:1 or so and dieseling occurs. IHC with Firecrater or high altitude pistons got same problem sometimes- H and 300 rods had about thickness of bearing shell difference- AC WD/WD45/175 may have same situation. Valve edge may be "sharp", that can develope hot spot also. RN
