TractorLinks.com
Show Parts for Model:
Re: WD continues to diesel after shut down
Butch(OH)
05-28-2014 05:28:30
What the others said is right on. One more point is that running on like that is telling you something that you should be paying attention to and that is you are running at, or darned close to detonation levels due to compression ratio and fuel quality. If it diesels or runs on only after a hard load and coolant is hot then you could be OK but should be listening very carefully for detonation under load. BUT!! If it is doing it when not hot or no loads have been applied then you are being duly warned by the engine that you need to do something now, prior to ruining it due to detonation. Cooler plugs? Maybe. Hot spot in chamber that can be fixed? unlikely. Better fuel needed? Most likely the problem. The cost of upgrading compression ratios in old tractors running todays junk fuel is you need to run mid grade or high test gasoline.
