WD Hydraulics
Them pump is internal, drawing oil from the sump. The fitting on the top of the valve has three ports which are pressurized.
Im trying to use a big bailers 2 cylinders, with, yes, 2 hoses. This QWD has been overhauled and WD 45 pistons have been put in it.
yopu are going to have to do some fabricating then,,, a wd is a one way system up and gravity down. will not work with your baler unless you add seprate control valve and return line .
He could do that, but likely hampered by volume and pressure issues. Pressure issue can be bypassed by adding a low pressure relief valve, but simpler to just add an aux system driven off the crankshaft pulley/front pump, with its own reservoir and pump.
