TractorLinks.com
Show Parts for Model:
Re: WD Hydraulics
JMS/.MN
05-26-2014 14:05:36
Them pump is internal, drawing oil from the sump. The fitting on the top of the valve has three ports which are pressurized.
Farmallb
05-26-2014 16:04:14
 Re: WD Hydraulics in reply to JMS/.MN, 05-26-2014 14:05:36
Yes, but im told that one has to be a inlet, and one an outlet. That right or not??
bg/mo
05-26-2014 16:20:00
 Re: WD Hydraulics in reply to Farmallb, 05-26-2014 16:04:14
wrong, all three are outlets. are you trying to use a cylinder with two hoses???
Farmallb
05-27-2014 07:37:33
 Re: WD Hydraulics in reply to bg/mo, 05-26-2014 16:20:00
Im trying to use a big bailers 2 cylinders, with, yes, 2 hoses. This QWD has been overhauled and WD 45 pistons have been put in it.
bg/mo
05-27-2014 09:59:47
 Re: WD Hydraulics in reply to Farmallb, 05-27-2014 07:37:33
yopu are going to have to do some fabricating then,,, a wd is a one way system up and gravity down. will not work with your baler unless you add seprate control valve and return line .
JMS/.MN
05-27-2014 16:23:40
 Re: WD Hydraulics in reply to bg/mo, 05-27-2014 09:59:47
He could do that, but likely hampered by volume and pressure issues. Pressure issue can be bypassed by adding a low pressure relief valve, but simpler to just add an aux system driven off the crankshaft pulley/front pump, with its own reservoir and pump.
