Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: D-14 Dead Miss
05-25-2014 21:16:18
I would first trying moving the fouled plug and/or wire to a different cylinder and see if the problem follows them. If it does the plug, wire or both are the problem and a tune up is in order. If nothing changes then you have either a ring or valve issue.
05-25-2014 21:40:01
 Re: D-14 Dead Miss in reply to funky_g00, 05-25-2014 21:16:18
I put a new set of plug wires on it a few months ago. I'll try a new plug and also moving the plug wire and see what happens.
The first couple of times it happened, I would clean the plug and it would run good for a few minutes before it went back to missing. But the last time or two I cleaned the plug, it seemed to have no effect. Maybe the plug is completely fouled now.
Dick L
05-26-2014 12:03:04
 Re: D-14 Dead Miss in reply to Palpatine, 05-25-2014 21:40:01
I have not had good luck cleaning a fouled plug more than a coupla time before they short out for good. I try to keep new plugs around and change out a fouled plug when it happens. Some times you can work the tractor under a heavy load several hours will stop the problem with clean oil.
