Allis B with mounted plow
Mark Poss
I am new to AC And I am looking at a mounted 1 bottom plow to put on a Allis B. Can someone post some pictures of one with a plow mounted on it? I just want to make sure all of the brackets are with the plow. Thankyou for your time, Mark.
If you send or post a picture, I can tell you if you have all the pieces. A picture of mine with the plows mounted is in the following discussion:
<a href="http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ac&th=132285">Two Way Plow Pictures</a>
The pallet with the brackets is not close by right now. Does the plow raise and lower with hydraulics or by lever. Thanks, Mark.
It depends, my B does not have hydraulics so it manual lift. The hydraulic option eliminates the long handles by the fenders and the large springs, and it has a slightly different rockshaft behind the seat. The plows, the plow drawbar, and the depth lever are the same regardless of how it is lifted. When you get a picture I can tell you more and get you the correct manual page.
