TractorLinks.com
Show Parts for Model:
Re: WD power unit
Hoenes
05-13-2014 17:29:51
JMS, I still have the "dry" clutch bolted to the engine. I'm sure you know the input shaft behind that stays with the "wet" clutch. (hand clutch/pto drive/ hyd.pump) unit. I'm not really interested in the side belt pulley, so I can do without that gearbox. I would like to find a factory conversion housing to reverse the shaft configuration (like you would see on the carnival units.) That way I can use it for whatever. I knew the 201 and 226 were the same, but other than that, I didn't know if any others would fit.
Hoenes
05-13-2014 17:41:50
 Re: WD power unit in reply to Hoenes, 05-13-2014 17:29:51
I should have also said that if I can find the factory type bell housing to make a power unit, the dry clutch comes off.
