Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: WD power unit
JMS/.MN
05-13-2014 15:43:37
125 (B,C engine) was common on lighter jobs, carnival rides, AC farm equipment, etc. Had diff bolt pattern than 201, 226. 201 and 226 have identical bolt pattern, used on heavier jobs like conveyors in quarries, etc. You say you have the clutch unit....what do you need? PTO, belt pulley?
Hoenes
05-13-2014 17:29:51
 Re: WD power unit in reply to JMS/.MN, 05-13-2014 15:43:37
JMS, I still have the "dry" clutch bolted to the engine. I'm sure you know the input shaft behind that stays with the "wet" clutch. (hand clutch/pto drive/ hyd.pump) unit. I'm not really interested in the side belt pulley, so I can do without that gearbox. I would like to find a factory conversion housing to reverse the shaft configuration (like you would see on the carnival units.) That way I can use it for whatever. I knew the 201 and 226 were the same, but other than that, I didn't know if any others would fit.
Hoenes
05-13-2014 17:41:50
 Re: WD power unit in reply to Hoenes, 05-13-2014 17:29:51
I should have also said that if I can find the factory type bell housing to make a power unit, the dry clutch comes off.
