TractorLinks.com
Show Parts for Model:
Re: B Valve Adjustment
BushogPapa
05-10-2014 19:44:30
Since the Rockers are worn where they contact the vale Stem, use caution when using a thickness gauge, or use a Dial-indicator...
Ron.
Mark - IN.
05-10-2014 21:30:41
 Re: B Valve Adjustment in reply to BushogPapa, 05-10-2014 19:44:30
Thanks Ron. I noticed as I guaged them that on some angles the feeler guage was tighter than others, wear. What I tried to do, was to find the wear and work based off of that. Seems ok. No chatter or anything of the sort. Used it to mow today. Tomorrow will drain the new oil and see if there is any antifreeze in it. Was a little antifreeze in the oil when I changed it a couple of weeks ago after setting in the barn for about 5 months during a brutal winter. First time ever for antifreeze in the oil. Not a lot, but enough to send up the flags. After cooling and setting over night, will drain it tomorrow and see if was a fluke, or going to have to take the head off and go after O-rings, sleeves, or...
Thanks again.
Mark
