7000 slippage
Anonymous-0
I have an older 7000 maroon belly tractor. tractor stops under load. what is the easiest way to tell if its the clutch or power director slipping? clutch pedal does have free travel. also if it has power director issues can the power director be pulled out just by splitting the tractor at the flywheel split? or does it need to be double split? thank you for any help.
