WF Clutch adjustment.
Anonymous-0
I just installed a new clutch in the WF and the free play is too much. The fork hits the release bearing just when the pedal hits the floor plate. The linkage is not adjustable on the outside, where does one adjust the clutch for wear or free play?
Did you adjust the clutch/pressure plate when you installed it? Adjustments are done through the inspection cover on the bottom side.
No I didn't adjust anything prior to installing the engine. This was a rebuilt clutch, normally the adjustments are all done. Where do I start?
