Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
WD won't stay running
TSWolf
04-17-2014 13:20:56
173.50.209.19
Last week, I bought a WD that had been sitting a few years. I basically rebuilt the ignition system (new plugs, wires, rotor, cap, points, condenser, coil). Also, I put new manifold gaskets on, as the old ones were leaking, so it was not creating vacuum through the carb.Now that that is all taken care of, when I try to fire up the tractor, it will only start if I put my hand over the intake of the carb, and will then only run for a few seconds and die. I did clean out the carb and put new gaskets and a needle and seat in it. I know it is getting fuel to it, when I pull the plug on the bottom fuel runs out in a steady stream. Has anyone else had this problem, or know what it could be?
[Reply]   [No Email]
TSWolf
04-18-2014 12:52:29
173.50.221.186
 Re: WD won't stay running in reply to TSWolf, 04-17-2014 13:20:56
I know the ignition switch is not the problem, as I just replaced it (and the tractor is getting spark). I also took the carb apart and cleaned it, and the main jet is not clogged up. I will try adjusting the float this weekend and see if that helps anything. Is there anything else I should check while in the carb? It is a marvel-schebler.
[Reply]  [No Email]
bjb in Tx from Ne
04-18-2014 05:11:58
147.1.234.163
Did you tear apart the carb completely? Sounds like the main jet is plugged. I have had an 8N ford and my honda motor on my tiller behave the same way. In both cases the main jet was plugged. On a zeinth carb, remove the needle or cap on the bottom left of the carb (mounted position) and the main jet can then be unscrewed. I usually use fishing line or plastic string trimmer line to clean the jets out.
[Reply]  [No Email]
bjb in Tx from Ne
04-18-2014 05:15:24
147.1.234.163
 Re: WD won't stay running in reply to bjb in Tx from Ne, 04-18-2014 05:11:58
Be sure in the future shut the fuel off and let the engine use up all the fuel in the carb to prevent the jets from plugging.
[Reply]  [No Email]
BushogPapa
04-18-2014 03:21:45
173.88.50.145
It must have a Distributor ( Battery Ignition).
Try bypassing the ignition switch..it may be that switch is bad..
You are aware of the typical "Cold-Nature" of an Allis..? They often do need a quick hand on the Choke, until they warm up a little..
Ron.
[Reply]  [No Email]
BushogPapa
04-17-2014 20:39:10
173.88.50.145
While you are checking the Float, double check the bottom passage that flows fuel to the "Power Screw".
That passage accumulates find sediment and can be blocked. You can un-screw the Power Screw (take it out) and tease a wire up into it, with the fuel on and get it fairly well open (if fuel flows)..
Ron.
[Reply]  [No Email]
TSWolf
04-17-2014 17:46:39
173.50.209.19
I will check the float. I also wanted to add that if I just use the choke on the tractor, it does not help. It only works if I completely choke it out by hand.
[Reply]  [No Email]
kub6040
04-17-2014 19:41:56
54.193.151.198
 Re: WD won't stay running in reply to TSWolf, 04-17-2014 17:46:39
I have had a few red tractors with warped manifolds , they won't seal!!!
[Reply]  [No Email]
soundguy
04-17-2014 17:00:35
207.30.46.70
When you have good spark but start and quick stalls, and choke helps some, check fuel delivery, may be stuck or heavy float or clogged fuel tap, screens, line, etc
[Reply]  [No Email]
Dirt
04-17-2014 14:08:42
75.148.34.117
Is the float leval set right
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
