HD3 Allis info?
Forum Members,
I am new to this forum, have been on N tractor forum for years. Question is I need an engine diagram for an HD3 Allis, I believe to be an 8-10-65. Trying to find the starter?? All I hear is a click which may be due to a poor battery connection.
Mr. T. Minnesota
The starter is located under the battery tray. You need to
remove the side panel under the gas tank to see it. Probably
need to remove both panels to get it out.
Chad,
Thanks for the reply! Thought is was in there some place, similar to other AC tractors. Looked around the bell housing and did not see a thing. Thanks for the info to get to the starter too. Am helping a party start the HD3. It has been setting for awhile. May put a bid on it if I can get it to turn over. If you have any other related info let me know. I believe it is a '65 model.
Mr. T. Minnesota
Had a problem once with exactly the same starter. Would turn over
and start...a minute later everything would be absolutely dead. Turned
out that the single bolt that holds the starter in place was
loose...preventing good ground connection. Once the bolt was tight
the problem was over.
