TractorLinks.com
Show Parts for Model:
Re: Allis Chalmers CA
Brutalfly
04-15-2014 05:49:48
Here are some pics of it
[/img]
maxwell99
04-15-2014 06:48:21
 Re: Allis Chalmers CA in reply to Brutalfly, 04-15-2014 05:49:48
others may chine in here,
but, if you use a ground Engaging tool like a plow, the draft control will not work with this 3 pt setup.
you must use the snap couple hitch and a snap couple plow for the draft control to work. it would be very hard to control the depth of the plow without the draft control, plow would have to have a check wheel mounted onto the side of the plow for it to work.
talk to some other guys that have used these tractors to be sure on this.
however, drag type equipment and bush hogs will work on this tractor, I used bracing check chains on my old D-14, so it would stop the bush hog at the same level each time.
Good luck,
Brutalfly
04-15-2014 06:53:27
 Re: Allis Chalmers CA in reply to maxwell99, 04-15-2014 06:48:21
So would a 1 or 2 bottom plow work with this or not?
I am not going to use a rototiller.
I don't know a lot about this style of tractor. I am kinda new to researching the Allis. I have spent most of my time researching Farmalls. Then I saw this tractor and liked it but did not know a lick about it.
maxwell99
04-15-2014 11:08:26
 Re: Allis Chalmers CA in reply to Brutalfly, 04-15-2014 06:53:27
I have included two pictures:
1. shows an AC plow with the snap couple hitch that goes up under a tractor like the CA and hooks to the snap coupler
2. shows a 3 pt hitch plow that you might use with an depth gauge wheel attached.
