Buda Forklift
Spudm
I have a very nice Buda forklift that I have owned for several years. It has a flathead four cylinder engine that runs great! My problem is the brakes went out, and I suspect the master cylinder, however I am not sure where it is located. Any advice? Thanks!
It should be under the floor plate, or attached to the frame. Follow the brake line back to it . I worked on them for years , great engine and a good machine . If the cyl is too pitted to rebuild , they can be sleeved and rebuilt w/original sized parts .
Once you figure out what you need, HGM Forklift Parts may be able to help you with replacement parts. They where the ONLY place that was willing to help us find a new head gasket for our Cat forklift back in January.
HGM Liftparts
Thanks for the advice! I will have to look a little closer, so far I have not located it, but I will. It must be under the floor plate, just have to figure out how to get to it.
