7010 Bush Hog, Plow
rustyal
What size bush hogs and plows can pull behind the 7000 series tractors. Looking at bat wing bush hogs they have the 2 pro speeds. What is the smallest plow you can use without destroying the plow. Any help?
I'd say you'd be fine with any 15' batwing. Might have to slow down a bit in heavy stuff, but shouldn't be a problem. As for the plow. Depends on how deep, how fast, and how many rocks you plow in. It'd probably play with anything less than 4 bottoms, I'd say 5 would be about right.
AaronSEIA
