7010 transmission pressure light
rustyal
Why would the transmission light be on. Tractor seems to run fine. Have not pulled anything with it yet. It is transmission pressure high light.
Is it a power director or a power shift transmission? Easiest check is electrical as stated. That is the most common issue.
Your trans. pressure switch should be on the filter housing
underneath the radiator. You should be able to follow the wire to
the rear of the engine. If electrical system is OK, you may have a
oil supply issue. You can access the suction screen by removing a
plate under and rear of the pump. If OK, you may want to flow
check the pump.
