fixer2u
Hey all I need your wisdom. Last time my brother pulled my uncle's WD it was missing pretty good under load, so I figure it's time for a tune up. Which magneto model might this be (this is the best pic I have available)?
Which autolite plugs are recomended for this mag model, and are the points and conencers on this site suitable?
Thank you in advance!
Nick
I have had great results with Autolite 295 plugs on all of my mag fired A-Cs. Whatever plugs you use don't use resistor plugs. Also make sure that you have real metallic wire plug wires, not carbon core or other types of resistor wires. Kip
Above all. NEVER allow even one drop of water in the sediment bowl..if it like mine, it will miss if there is..
Been that way for many years.
Ron.
