Don Ober
I have a head from a WD45 , it is a 4 icnh head that I had rebuilt for my wc but found that it is a3 inch head so now it sits on the shelf for the past three years with all new valves and giuds can t use it. What is it worth? Thanks
Don't know what it is worth, but depending on where you are I may be interested. My WD head has a crack in it, still runs good but seeps coolant into the oil so I run unpressurized.
Lots of WC allis tractors out there with WD45 heads on them. Get the longer head studs and push rods and put it together. It is a much better head.
Jim
Push rods are all the same- rocker arm stands are shorter on tall head to make up for it, valve cover is also shorter. Only advantage with tall head is slightly better cooling and less shrouding of spark plug in cylinder.
I was wondering the same thing.... just too dumb to remember and contribute, but I knew they could be used on the 201. Older I get, more I forget...or, didn"t know in the first place!
