bison
Neighbor dropped off a allis 200 diesel (clutch went out) to get fixed. I don't know nothing about these models and very little about Allis to start with
Is there anything special i need to do/know involved in splitting the tractor?
thanks.
If you pull the flywheel, make sure you replace both the wear sleeve and the rear seal. Also, put a bolt in backwards on the frame rail to hold the engine plate up on each side.
Hurst
Very easy job to do along with what has been said
there are 2 O rings on the engine adapter plate that
need replaceing too- any more questions just ask but
a 200 clutch is an easy job
What you mean is that the cable on all the other makes works backwards. It's easier to push it in in an emergency than it is to pull it out.
