6080 steering problem
Our 6080 allis started steering to the left on startup anytime the tractor is cold. You really have to fight the wheel to use it until it warms up a little. Bit by bit as it runs longer, it gets easier to steer, until it steers normally. Steering hydromotor centering springs? Ideas
spring could be weak but also i say it has some small metal trash in it the motor take apart clean it good replace the springs should be good to go
