Yesterday's Tractor Co. Fast, Friendly Parts Service
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
piston install question
andyin ct
03-09-2014 05:50:31
108.250.158.13
On an allis C I am putting new pistons in - does the notch go to the front of the motor? Old pistons don't have notch. Thanks
[Reply]   [No Email]
B t
03-10-2014 08:59:19
174.236.38.53
 Re: piston install question in reply to andyin ct, 03-09-2014 05:50:31
Every motor I've ever worked on, car or tractor, notches always go to the front.
[Reply]  [No Email]
Dick L
03-10-2014 17:34:18
50.51.157.16
 Re: piston install question in reply to B t, 03-10-2014 08:59:19
I totally agree with that except new pistons made only for these engines will not have notches. The pistons he has, if correct for the engine, would have to have been made for more than one engine make.
[Reply]  [No Email]
Mike(NEOhio)
03-09-2014 13:24:47
162.40.57.21
Are they aftermarket parts? Check the pistons for an offset wrist pin. I just got cylinder kits for a Buda. The pistons have FRONT cast in and a notch on the crown. I noticed later that the pins are offset to the thrust side.
[Reply]  [No Email]
Dick L
03-09-2014 06:49:16
50.51.157.16
Notches on the pistons are normally for oil drainage from behind the rings when the pistons run on a slant. Running straight up and down the oil will drain the same each way. It does look better to have the notches going the same way to an observer. It is a pride in your work thing.
[Reply]  [No Email]
Dick L
03-09-2014 06:43:22
50.51.157.16
It makes no difference on this engine. Make sure that you refer to the post below with the picture of the offset rod cap ends and how they must be installed. If you want the notches to go forward make sure you place the rods the correct direction on the piston by alternating them. If the rods are put on wrong they will bind and can bend the rod causing you to get new or different rods.
[Reply]  [No Email]
andyin ct
03-09-2014 08:52:04
108.250.158.13
 Re: piston install question in reply to Dick L, 03-09-2014 06:43:22
Thanks - I noticed the rods offset when I took motor apart.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
