190 tranmission leaking
J190
my 190 is leaking transmission oil that I can see visibly on the ground. where would this be coming from and what would be the process of fixing this. It is not leaking into the hydraulic side because that level stays the same. any help would be appreciated! Thanks
Not many places for it to leak. Visually inspect it closer and it should be obvious. Maybe a rear PTO seal or PTO housing gasket, or a gasket on the drain plug.
