7010 Crankshaft Pulley
rustyal
Just brought home a 7010. Trying to work on a few problems. The main thing that jumps out at u is the pulley wobble is making the pulley rub aginst the housing. Wondering why I wobbles around so much? Also, after changing the oil there is now a new oil leak at the turbo. Could slightly over filling the oil cause that? The fuel system is not to bad. Just one big leak at the rossa master pump fuel cut off shaft. Do u have to pull the whole pump to replace that seal?
Rubber dampner in pulley is bad. Get a new pulley. Oil leak on turbo may just be oil feed line at top. 3/8 rubber sleeve will fix that. Any implement dealer will have that. Leak on throttle and shut off shaft in pump can be easily repaired with out removing pump
Don"t run the tractor until you replace the dampner pulley. If it fails there"s a good chance it"ll go thru the radiator.
