ohiojim
splitting a D17, have everything unhooked and unbolted as far as I can tell,..this is a 59 or 60 gas model. can't seem to get it to split, is there something on the hand clutch that needs to be addressed ?? any help appreciated
yes u need 2 remove cover by powerdirector and remove fork its easy once u see it I think its a bolt with a lock nut on it. ill look 4 a pic
powerdirector clutch
I see the power director shaft with the bolt and lock nut,..when it comes apart the clutch pack will be on the rear part as you have pictured ????
