D-17 belt pulley
Pumkin
New User
I am needing a belt pulley for my D-17.
I have the drive, just need the pulley itself.
It should have 6 bolt holes to fasten to the drive hub.
Any help is appreciated.
Thanks, Rob.
I have used a wd pulley with an adapter made by my local welder. He welded a machined shaft for the pulley on a machined round plate with the mounting holes to fit on the drive. I had two made that way.
Hey Den,
Can you call me sometime or give me your number and I will call you.
Thanks,
Rob
573-819-seven zero 32
