Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Making a power unit out of WD?
TWL
02-05-2014 07:34:37
206.162.202.234
I'm making a power unit of of a junked wd.I only have the engine and transmission. I want to run a belt pulley to a feed grinder. I have the engine on a running gear. I don't know what to do with the imput shaft from the transmission. I need it to run the belt pulley. Would any of you have any idea on how to make this work. Thank you for your help.
[Reply]   [No Email]
TWL
02-08-2014 16:21:18
206.162.222.164
 Re: Making a power unit out of WD? in reply to TWL, 02-05-2014 07:34:37
Thank you all for the help. TWL
[Reply]  [No Email]
DonBC
02-06-2014 09:17:18
70.67.10.108
If you cut off the transmission shaft you would have to put a good sized pillow block bearing at the end of the shaft. This would hold the shaft in place and couteract the side thrust from the belt.
[Reply]  [No Email]
Tramway Guy
02-06-2014 08:33:08
64.185.154.188
According to the AGCO parts books, the clutch housing for a WD and WC have the same part number. So a WC transmission would bolt right on and provide you with an easy way to use the regular belt pulley form a "W" series tractor.
[Reply]  [No Email]
BushogPapa
02-05-2014 16:05:23
173.88.50.145
At one time, every ride at the "Fair" was powered by one of these AC Power-Plants..
Sorry I do not remember what the rear of the unit looked like..
Ron.
[Reply]  [No Email]
steve(ill)
02-08-2014 06:21:43
74.36.188.59
 Re: Making a power unit out of WD? in reply to BushogPapa, 02-05-2014 16:05:23
Most units at the "fair" were CE125 motors like a B or model C tractor. THey were fixed up with a bell housing with a clutch and PTO drive mounted into the special bell housing. THey did not use the tractor bell housing or transmission parts.
[Reply]  [No Email]
Tramway Guy
02-05-2014 14:50:19
64.185.154.188
You need to have the bell housing, shaft and something to support the shaft. Rather than the WD torque tube as in a WD tractor, A WC transmission might be the simplest. It should bolt onto the bell housing and thereby provide support for the bevel gear that drives the WC/RC/WD belt pulley attachment.
Maybe the WD transmission will work also (without the torque tube in between), but I doubt it).
[Reply]  [No Email]
m-m jac
02-05-2014 13:58:13
63.135.145.148
if you have motor/bell,trans. you will have the pulley or the hole for pulley , install ,done'''.
[Reply]  [No Email]
TWL
02-06-2014 06:24:25
206.162.222.26
 Re: Making a power unit out of WD? in reply to m-m jac, 02-05-2014 13:58:13
The input shaft from the WD stays with the transmission when it is separated. I think I have to cut the shaft but I dont know how to keep it in the bell housing.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
