CA hyd pump
What part of North America do you live in? If you are in a cold weather climate replace your hydraulic oil filter and add some kerosene to your oil. Just finished helping the neighbor resolve the same problem
Sounds like a good cleaning of the pump and valve might be in order. New fluid don't help if there is old nasty stuff in there that isn't flushed out.
The lift arms will go down hard even in warm weather but you could have a plunger sticking.
If it won't go up now, you might have the bypass spool stuck back or a broken spring on it.
