TractorLinks.com
Show Parts for Model:
Re: WD what size of disk?
Leroy
02-03-2014 05:56:17
In spring if disking down corn stalks first time over probably, anytime after plowing no, not even with duals. Look for something like a John Deere KBA in either the wheel or drag versions with 6 blades on a side for total back gang cutting width of 7'6". Most populsr und used disks when they were made. Forget a mounted for field work, only for garden size plots. Then you would need front weights to hold front down in travel but then they would make it too hard to turn with no weight on back. That tractor would be about equal in what it could pull to a Farmall H or John Deere B. Sold as 3 plow but would not handle it, Uncle mile down road bought new outfit, 3 bottom and 3 bottom was laying in shed, Anough uncle a bit other way in different ground had WD 3-12" setup and would handle it in that ground, outfit burned in barn fire, Bought different WD and 3-14", could not pull it. And where he pulled the 3-12" I could also pull that same size with the John Deere B.
