Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: WC RH Axcle, can't get pinion gear off
JoeM(GA)
02-02-2014 13:47:39
I might be wrong, but weren't the early ones two piece and the later ones made together?
Nebraska Cowboy
02-02-2014 17:00:59
 Re: WC RH Axcle, can't get pinion gear off in reply to JoeM(GA), 02-02-2014 13:47:39
Not sure what you mean, on the other side, the gear came off real easy, was held on by a key in the shaft.
JoeM(GA)
02-02-2014 17:43:01
 Re: WC RH Axcle, can't get pinion gear off in reply to Nebraska Cowboy, 02-02-2014 17:00:59
Didn't know you'd had the other side off. I have seen some that have had an axle broken before and ended up with a solid one and a two piece style.
You may find it will need more than most 12 ton presses will put out. A bit of heat shouldn't hurt anything.
Copyright © 1997-2015 Yesterday's Tractor Co.
