Wd 45 wide front rebuild questions
I just got a 4 bolt wide front to put on my wd45 loader tractor.I decided to completely disassemble it to check all bearings and races. I have it all apart except the big gear off of the vertical shaft. I have an i&t manual but it doesn"t talk about removing that gear.I don"t see a set screw on that gear. I also think it needs the lower seal replaced and if I can find one I"d like to replace the seal on the steering shaft.
