TractorLinks.com
Show Parts for Model:
Re: WD With 38
old
01-27-2014 20:45:41
Should have something like a 12.4X28 on it so yes speed will be upped some. How much I can not say. But if you use 1st gear to bale with should not be to fast unless you have big windrows. If it sat that long I would do an ATF treatment to the engine to make sure the rings are freed up and cylinders well lubed before starting it up. Also look on the right hand side of the engine for a bolt on plate. It is has one it is a WD engine if it does not you may have found an early WD45
