60 ALL CROP COMBINE
BillOHIO
I noticed early on that a lot of Dad's friends and customers had AC 60 ALL CROP COMBINES. Everything else these farmers had was mostly IH but they liked those combines. Once in a while they replaced the Farmall M that most of them pulled the combine with a WD or WD-45. I wondered what is deal as M heavier and more power, why buy another tractor to pull the combine. Matching paint ? I asked Dad and he grinned and said watch them going thru field with Allis in heavy crop. So I did and noticed the tractor would stop when they pulled the lever and combine would keep running. So a live P.T.O. which the Farmall did not have was the big plus !
I told Dad I see the reason. He said yes but I need to remember to tell those guys with M's about the new add on M&W CLUTCH that I can install and will do the same thing as the AC clutch.
No one that I remember got rid of their AC Tractors after they had them as they were handy nimble tractor as I found out.
Some did get different color combines as larger straight thru design machines became available.
Most kept their AC 60'S as backup and to run clover seed and other grass seed, however.
One thing I just thought of with the AC 60 Combine and it's sideways threshing system.
Years later when the first Gleaner rotarys came out. Crop in and then sideways rotor compared to IH Rotor which ran crop straight thru.
Bill
I grew up around a 66 Big Bin. First combine I bought was an AC 90 in 1993. I found them cheap, & easy to operate compared with the self propelled combines. Didn't have another engine, or transmission to maintain!
one thing I can remember about those old combines.
I drove the tractor around in the field pulling a wagon, helped my dad pick up the sacks of seed and place them on the wagon.
I remember watching the guy on the combine having to stand up there in the dust and dirt and tie up the bags.
after watching him work for a while, I did not think my job of primary tractor driver was so bad.
that old combine might have been older than a all crop 60. But it worked good and they all said the seed was clean.
would really be a rough job having to sack and tie up bags from one of these new combines.
