mikeintn
I have a 1959 D-14 that the hyd leaks down on, goes up ok but wont stay, anyone knows what I may be looking at to fix it? Thanks
If the oil in the transmission/rearend is rising you have a leaking hose or cylinder inside the housing. You have to pull the lift arm housing to find and fix this. If not you have a hold valve problem with the pump, not sure on that model if you have to pull the pump to get at it or not? Somebody else here will likely know for sure.
I sure I will learn more when I get into it, sounds like the pump, if so are these available or parts to rebuild? Thanks Butch
