G brake drum
rp1555
I am wanting to take of the brake drum on a G so I can put in the outer axle bearing. will it press off or is there a special puller used ?
I see there's an axle, shaft, drum assembly available on eBay now - not mine! I learned that one thing to watch for is that many of these original rear axles have been broken at the inner seal/bearing location, re-welded and ground down. If the repair is done well, as I found on my G, I guess it's OK
Wengers (Myerstown PA) has the rear axle housing. Before visiting their website and searching for the part make sure your heart can handle the sticker price!
