Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Allis chalmers C generator wiring
chalmersbob(pa)
01-07-2014 19:14:15
You MUST remove the field wire from the amp meter.
The F wire goes to ground as was stated. If you connect the F wire directly to ground the genny will put out 10+ amps, but grounding through 3 ohm resistor it will charge 2-3 amps. You can do this though a toggle switch. hook the F wire and a 3 ohm resistor to 1 terminal of the switch and a wire from the other terminal and the loose end of the resister to ground. With the switch off the F wire grounds through the resistor. With the switch closed (on) the F terminal is connected directly to ground. Path of least resistance. Bob
