TractorLinks.com
Show Parts for Model:
Re: Allis chalmers C generator wiring
Ted in NE-OH
01-07-2014 18:51:12
It is fried because someone hooked the field terminal to the amp meter which is at battery voltage. The field only goes directly to GROUND (high charge) or to Ground thru a resistor for (low charge,)
chalmersbob(pa)
01-07-2014 19:14:15
 Re: Allis chalmers C generator wiring in reply to Ted in NE-OH, 01-07-2014 18:51:12
You MUST remove the field wire from the amp meter.
The F wire goes to ground as was stated. If you connect the F wire directly to ground the genny will put out 10+ amps, but grounding through 3 ohm resistor it will charge 2-3 amps. You can do this though a toggle switch. hook the F wire and a 3 ohm resistor to 1 terminal of the switch and a wire from the other terminal and the loose end of the resister to ground. With the switch off the F wire grounds through the resistor. With the switch closed (on) the F terminal is connected directly to ground. Path of least resistance. Bob
