Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Allis chalmers C generator wiring
Darrell Hopper
01-07-2014 12:59:05
After I posted my questions,I removed and disasembled the generator. The generator is fried. I assume that when the lights and switch was removed that there wasn't any voltage control and that must have burnt up the generator.
01-07-2014 16:20:58
 Re: Allis chalmers C generator wiring in reply to Darrell Hopper, 01-07-2014 12:59:05
The light switch puts a resistor in series with the "F" wire to ground. When the lights are on, it bypasses the resistor and grounds the "F" directly. Grounding the "F" wire is a test to see if the generator is working. You dont need the higher charge all the time. IF you take the light switch out of service, you can add a big resistor on the "F" wire to ground so you get a constant 2-3 amp charge. I think its 3 OHMS, but no guarantee without looking it up.
01-07-2014 16:23:25
 Re: Allis chalmers C generator wiring in reply to steve(ill), 01-07-2014 16:20:58
The cutout should be open when not in service. When the generator is running and putting out voltage above the battery, the cutout closes and current flows to the battery. If the battery flows backward when off, the cutout is bad.
