Anonymous-0
I have a C allis that the generator is not working. Someone removed the lights and light switch and hooked the field wire from the light switch to the negitive side of the amp meter. So there is no voltage control without the light switch. How can I fix the problem without insatlling a light switch? The amp meter is good but I do not know if the generator or cutout relay is good. I do know that when I hook up the battery ground wire that there is a current flow through the generator. If I disconnect the armature wire from the cutout relay the current flow stops. Is this telling me that the relay or generator is bad?
Thank you for your help
