Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Allis chalmers C generator wiring
Darrell Hopper
01-07-2014 09:21:39
216.107.177.173
I have a C allis that the generator is not working. Someone removed the lights and light switch and hooked the field wire from the light switch to the negitive side of the amp meter. So there is no voltage control without the light switch. How can I fix the problem without insatlling a light switch? The amp meter is good but I do not know if the generator or cutout relay is good. I do know that when I hook up the battery ground wire that there is a current flow through the generator. If I disconnect the armature wire from the cutout relay the current flow stops. Is this telling me that the relay or generator is bad?
Thank you for your help
[Reply]   [No Email]
darrell Hopper
01-08-2014 06:28:12
216.107.177.173
 Re: Allis chalmers C generator wiring in reply to Darrell Hopper, 01-07-2014 09:21:39
Thank You everyone for your help and knowledge. Now all I have to do is decide whether to install an alternator or find a 6v generator. I think it will be cheaper to get an alternator but if I find a generator I will have your knowledge to do it correctly.
Thanks again
[Reply]  [No Email]
Bob Bancroft
01-08-2014 09:31:29
67.142.162.21
 Re: Allis chalmers C generator wiring in reply to darrell Hopper, 01-08-2014 06:28:12
Another possibility. I put a D series, 2 brush 12 V gen. and regulator on my C when I got it. Works great.
[Reply]  [No Email]
Ted in NE-OH
01-07-2014 18:51:12
65.25.30.63
It is fried because someone hooked the field terminal to the amp meter which is at battery voltage. The field only goes directly to GROUND (high charge) or to Ground thru a resistor for (low charge,)
[Reply]  [No Email]
chalmersbob(pa)
01-07-2014 19:14:15
71.175.240.128
 Re: Allis chalmers C generator wiring in reply to Ted in NE-OH, 01-07-2014 18:51:12
You MUST remove the field wire from the amp meter.
The F wire goes to ground as was stated. If you connect the F wire directly to ground the genny will put out 10+ amps, but grounding through 3 ohm resistor it will charge 2-3 amps. You can do this though a toggle switch. hook the F wire and a 3 ohm resistor to 1 terminal of the switch and a wire from the other terminal and the loose end of the resister to ground. With the switch off the F wire grounds through the resistor. With the switch closed (on) the F terminal is connected directly to ground. Path of least resistance. Bob
[Reply]  [No Email]
old
01-07-2014 09:43:06
209.86.226.27
First thing I would do is check battery voltage with it not running then check it with it running. Not running you should have around 6.3 volts and with it running around 7 or so volts
[Reply]  [No Email]
Darrell Hopper
01-07-2014 12:59:05
216.107.177.173
 Re: Allis chalmers C generator wiring in reply to old, 01-07-2014 09:43:06
After I posted my questions,I removed and disasembled the generator. The generator is fried. I assume that when the lights and switch was removed that there wasn't any voltage control and that must have burnt up the generator.
[Reply]  [No Email]
steve(ill)
01-07-2014 16:20:58
74.36.188.59
 Re: Allis chalmers C generator wiring in reply to Darrell Hopper, 01-07-2014 12:59:05
The light switch puts a resistor in series with the "F" wire to ground. When the lights are on, it bypasses the resistor and grounds the "F" directly. Grounding the "F" wire is a test to see if the generator is working. You dont need the higher charge all the time. IF you take the light switch out of service, you can add a big resistor on the "F" wire to ground so you get a constant 2-3 amp charge. I think its 3 OHMS, but no guarantee without looking it up.
[Reply]  [No Email]
steve(ill)
01-07-2014 16:23:25
74.36.188.59
 Re: Allis chalmers C generator wiring in reply to steve(ill), 01-07-2014 16:20:58
The cutout should be open when not in service. When the generator is running and putting out voltage above the battery, the cutout closes and current flows to the battery. If the battery flows backward when off, the cutout is bad.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
