What year is my Allis Chalmers b
Gerald12
New User
I am looking for the year of my Allis b model;
number near the stick shift is B47100
and the two numbers on the engine block are;
M-2916-12
K17y
B47100 would be the serial number. It is a 1940 model. Serial number information is available under the Reserach and Info information on the Yesterday"s Tractors website or at: www.tractordata.com
Look to the left of this page under research and info then serial numbers then A/C then B and see where those numbers fit. Sorry I will tell you how to help your self but I will not go look for you
M-2916-12 is a casting number most likely a 1940 engine. The engine serial number should be stamped on the left rear engine flange where it bolts to the bell housing. That should be in the range of CE33882 to CE50391.
thank you for your reply i am not quite sure i understand i take as granted the left hand side is from driver s seat position the engine serial number is it near the radiator and generator or near the fly Wheel gear thank you very much gerald12
(quoted from post at 17:09:43 01/13/14) thank you for your reply i am not quite sure i understand i take as granted the left hand side is from driver s seat position the engine serial number is it near the radiator and generator or near the fly Wheel gear thank you very much gerald12
Engine serial # is near the bellhousing, flywheel, clutch area.
