B W in MO
Was useing it loading some wheel wts and something poped in the rear it will not move. I can change gears all it will do is pull motor down. Just wondering what could of happened.
You may have broken a gear or some such thing in the transmission or maybe broken something in the rear end etc. Depending on where you are in MO I have a WD parts tractor which has the transmission and rear end still there but the engine is gone
If it did it when changing gears you may be in two gears at once due to gear shift lever jumping out . To fix remove gear shift lever and move forks with long screwdriver
Since you say you can change gears, I assume your lever is still intact and engaged. Apparently you can feel the detents, etc. like normal? If so, maybe a fork is broken.
Thanks guys I finle got to feeling better today went out and checked into it some more and it was in two gears. I'v had it to do that before but not to make a loud pop noise like that. Thanks again, B W
