WD parts sources
Jr64
I"m rebuilding the family WD. Looking on the internet I see several places with some of the parts I need. I"m looking for suggestions for a "one stop shop". I need everything from an engine overhaul kit, transmission seals and gaskets as well as a new hand clutch, a shifting fork, sheet metal, radiator, etc.
You can buy a lot of that from this site and help them keep the site going. As for just one place to find that all I almost bet you will need to look around for this and that
Now is the time...
You might as well put a WD-45 Crank in it and a 9 spring clutch Pressure Plate in it NOW..
You will always be glad you did..!
(Either way, go with the 4 1/8" kit)..
Ron.
