hydraulic pump wd45
Andy Keil
My hydraulic pump wasn"t working so I took it off. it says in the service manual that all rollers need to be at 2 1/8" high. well only one of mine were and I am curious how to fix it. I can"t even pull them up to get them at the right height. or do i just replace the rollers? thanks
You are correct about the rollers needing to be out 2 1/8", but the rollers are not the problem. They push in and release the plungers of the pump that are each backed by a spring. The pressure of the spring would be what projects the roller out. Maybe a broken spring or just a good cleaning?? Keep us posted and will TRY to help. Ryan
