Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Allis C oil priming problems
12-15-2013 16:06:10
I am having trouble with the oil pump staying primed on my C. When this happens I take the line off by the tee that goes to the filter housing, squirt in some oil, put the line back on, then start it and the pressure comes up immediately. However, when I shut the tractor off for 2 days or longer I have to go through this whole process again. Any help on what is going on here would be greatly appreciated!!!
Dick L
12-16-2013 12:48:02
 Re: Allis C oil priming problems in reply to 210magnum, 12-15-2013 16:06:10
If it be me, I'd drop the pan first to see if the suction pipe is cracked or loose. If the check ball is real bad it will not give good oil pressure. It could be the pump cover wore out and lets the oil drain back into the pan. That would only be checked by removing the oil pump.
Ted in NE-OH
12-15-2013 17:15:33
The check ball in the oil pump may be damaged or the check spring broken. Unfortunately you have to split the tractor.
12-15-2013 17:27:36
 Re: Allis C oil priming problems in reply to Ted in NE-OH, 12-15-2013 17:15:33
O.K. Thanks for the help.
12-15-2013 16:09:28
Do you get decent pressure when it is running?
12-15-2013 16:11:46
 Re: Allis C oil priming problems in reply to JMS/.MN, 12-15-2013 16:09:28
