TractorLinks.com
Show Parts for Model:
Re: b-125 crank kit
tim lockey
12-10-2013 19:38:15
Thanks for helping me understand this Dick L checked w/ plastigage, way too tight, crank wont rotate, this with STD as new crank, and STD bearings. Where can i order the correct shims for both mains and rods? No AC dealers left in eastern NC. Thanks
steve(ill)
12-12-2013 18:55:41
 Re: b-125 crank kit in reply to tim lockey, 12-10-2013 19:38:15
If the crank was "standard" and the bearings are "standard", then you will need about .006 inch of shims on each bolt. They sell .002 shims ( x 3) or like DIck said, you can cut you own. I have a brass sheet .002 thick and have made several. The shim goes around the bolt, but dont get it caught under the edge of the bearing.
Dick L
12-11-2013 10:13:38
You can get them from Sandy Lake Implement and you might get them from this site. I cut my own from shim stock. Some cut them from pop cans.
The shim packs you get from a dealer would be easier for someone that has not done this before.
